[GRASS-dev] [GRASS GIS] #2151: g.gui.* modules which use temporal framework leave processes after exiting
GRASS GIS trac at osgeo.org
Thu Jan 2 20:25:50 PST 2014
 Reporter:  annakrat                        |       Owner:  grass-dev@…
     Type:  defect                          |      Status:  new
 Priority:  normal                          |   Milestone:  7.0.0
Component:  Python                          |     Version:  svn-trunk
 Keywords:  g.gui.animation, temporal, RCP  |    Platform:  Linux
      Cpu:  All                             |
Comment(by annakrat):
 Replying to [comment:8 huhabla]:
 > The patch is not applied yet, since it does not solve the issue that the
 child process is still alive. Maybe an explicit os.exit() should be added
 to g.gui.timeline? How about an exit button?
 os.exit would close the whole wxGUI when the timeline tool is called from
 the wxGUI. Exit button would not solve anything, it just does the same as
 the standard x close button or Alt+F4. I tried it to be sure and there is
 no difference. I think you can commit your changes, it's improvement.
 Could the problem come from the matplotlib? Maybe I am using it in an
 incorrect way.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2151#comment:9>
