[GRASS-dev] wxPython 3 support
Anna Petrášová kratochanna at gmail.com
Sun Jan 12 15:31:43 PST 2014
On Sun, Jan 12, 2014 at 5:40 PM, Maciej Sieczka <msieczka at sieczka.org>wrote:
> Hello,
> Can you please tell what is the status of wxPython 3 support in SVN GRASS6
> and 7?
so far I tested grass 6 and 7 with wxpython 2.9 only. I am not sure what's
the difference between 2.9 and 3 but I hope it's not so big.
> There is a problem on Arch Linux, which has just replaced 2.8 with 3.0,
> and GRASS 6.4.3 says "ERROR: wxGUI does not support wxPython 3.0.0.0 yet"
> to that.
GRASS 6.4.3 was not yet working with newer wxPython, that's why you get the
error. Current GRASS 6.4 branch should somehow work although I was not able
to test the whole wxGUI, so you can expect some glitches. I would
appreciate if you can test and report errors which can be related to new
wxPython.
> Trunk G7 and 6 build OK against wxPython 3.0. On a very quick runtime
> check I noticed they frequently throw the following errors though:
> G7:
> /opt/grass70-svn/etc/gui/wxpython/gui_core/goutput.py:234:
> wxPyDeprecationWarning: Call to deprecated item 'SetVirtualSizeHints'.
>   self.outputSizer.SetVirtualSizeHints(self.panelOutput)
Nothing critical, I didn't remove it yet because I'm not sure if it's
needed with wxPython 2.8.
> (wxgui.py:11592): Gtk-CRITICAL **: IA__gtk_widget_set_size_request:
> assertion 'width >= -1' failed
> assertion 'height >= -1' failed
> G6:
> (wxgui.py:18284): Gtk-CRITICAL **: IA__gtk_widget_set_size_request:
I think it doesn't really break anything (right?) and it's hard to track
what's the problem so I usually ignore it.
Thanks for reporting,
Anna
> Maciek
> Maciej Sieczka
> http://www.sieczka.org
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140112/0b81cc0a/attachment-0001.html>
