[GRASS-dev] Changes between Python 2 and Python 3 that might need attention in GRASS
Moritz Lennert mlennert at club.worldonline.be
Mon Jan 13 08:25:53 PST 2014
On 13/01/14 16:13, Vaclav Petras wrote:>
> One important change I stumbled upon recently is that integer
> division results in float in python 3, while it resulted in integer
> in python 2. So any module that relies on integer division resulting
> in integer will need to be updated. I have no idea if such situations
> exist, though.
> If it is as you say, you may mention that in some separate email
> thread and not hidden here in a wxPython GUI thread.
Your wish is my command ! ;-)
Here's the doc:
http://docs.python.org/3/whatsnew/3.0.html
Issues I think might need attention (but this is without verification
within the grass python code):
- Print Is A Function
- Views And Iterators Instead Of Lists
- PEP 0238: An expression like 1/2 returns a float. Use 1//2 to get the
truncating behavior.
- Text Vs. Data Instead Of Unicode Vs. 8-bit
Moritz
