[GRASS-dev] [GRASS GIS] #1635: allow r.los to run with a point vector layer as input for "coordinate identifying the viewing position"
Markus Neteler neteler at osgeo.org
Mon Jan 13 14:25:10 PST 2014
>  In r58688, I changed `xy` to standard `coordinates` option which enables
>  to interactively pick coordinates from map display if you start G7:r.lake
>  from the main GUI command console, menu or module tree.
>  Neither of these three supports multiple coordinates input, although
>  G7:r.lake supports it using seed raster which makes more sense in this
>  case except for cases when you want to add just few points (e.g. 2). The
>  important thing is that supporting multiple coordinates goes far behind
>  supporting more inputs, probably algorithm itself needs to be improved to
>  fulfill the multiple point input required by the original request.
>  Separate tickets for each modules would be better in this case.
For the record: I check (hopefully) all other GRASS 7 modules, here
the remaining candidates for update to use G_OPT_M_COORDS:
 * display/d.profile/main.c (maybe)
 * misc/m.transform/main.c (maybe)
 * raster/r.circle/main.c
 * raster/r.horizon/main.c
Markus
