[GRASS-dev] [GRASS GIS] #2121: v.rast.stats: allow choice of statistics
GRASS GIS trac at osgeo.org
Wed Jan 15 00:22:02 PST 2014
 Reporter:  mlennert      |       Owner:  grass-dev@…
     Type:  enhancement   |      Status:  new
 Priority:  normal        |   Milestone:  7.0.0
Component:  Vector        |     Version:  svn-trunk
 Keywords:  v.rast.stats  |    Platform:  Unspecified
      Cpu:  Unspecified   |
Comment(by mlennert):
 Replying to [comment:2 lucadelu]:
 > I added a ''method'' option to choose the methods to save in the
 attribute table in r58726.
 This is great, thanks ! Just one problem: it fails at lines 255-256 with
 the dbf driver as colnames get truncated, but your variable names are
 full, and so
 variable = colname.replace("%s_" % colprefix, '')
 i = variables[variable]
 leads to a key error since 'variable' does not exist in 'variables'. A
 solution might be to use a dictionary linking variable names to colnames ?
 > I would like also to remove ''-e'' flag and add the methods calculated
 by extended statistics to the ''method'' 's options, what do you think?
 Sounds reasonable to me.
 Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2121#comment:4>
