[GRASS-dev] GRASS 7 r.what introduces duplicates
Markus Metz markus.metz.giswork at gmail.com
Tue Jan 21 00:15:31 PST 2014
On Tue, Jan 21, 2014 at 9:02 AM, Blumentrath, Stefan
<Stefan.Blumentrath at nina.no> wrote:
> Wow, fixed before I managed to open a ticket!
You can open a ticket to backport the fix if it is working for you.
The fix itself is trivial.
Markus M
> Thank you very much Markus!
> -----Original Message-----
> From: Markus Metz [mailto:markus.metz.giswork at gmail.com]
> Sent: 21. januar 2014 08:40
> To: Luca Delucchi
> Cc: Blumentrath, Stefan; GRASS developers list (grass-dev at lists.osgeo.org)
> Subject: Re: [GRASS-dev] GRASS 7 r.what introduces duplicates
> On Tue, Jan 21, 2014 at 12:50 AM, Luca Delucchi <lucadeluge at gmail.com> wrote:
>> On 21 January 2014 00:42, Blumentrath, Stefan
>>> Hi Luca,
>> Hi Stefan,
>>> Thanks for your reply. I investigated a bit more and suspect the problem arises from the "points" option which I used....
>>> When I extract the coordinates from my vector map and feed them as a list to the "coordinates" option I get the correct number of lines from r.what (like you did). But when I use the same file directly in the points option the last line is duplicated (using r 58048 btw.).
>> Yes you are right, please open a ticket...
> Fixed in trunk r58752.
> Markus M
>>> Cheers
>>> Stefan
>> ciao
>> Luca
>> http://gis.cri.fmach.it/delucchi/
>> www.lucadelu.org
>> grass-dev mailing list
>> http://lists.osgeo.org/mailman/listinfo/grass-dev
