[GRASS-dev] [GRASS GIS] #2171: rfe r.in.gdal: auto-calc memory= value
GRASS GIS trac at osgeo.org
Fri Jan 24 00:31:41 PST 2014
 Reporter:  hamish                    |       Owner:  grass-dev@…
     Type:  enhancement               |      Status:  new
 Priority:  normal                    |   Milestone:  7.0.0
Component:  Raster                    |     Version:  svn-trunk
 Keywords:  r.in.gdal, GDAL_CACHEMAX  |    Platform:  All
      Cpu:  All                       |
Comment(by mlennert):
 Replying to [ticket:2171 hamish]:
 > Hi, a r.in.gdal wish refined with hints from EvenR,
 > it would be nice if the r.in.gdal memory= option allowed the user to
 specify memory=auto, in which case the value was automatically calculated
 from "tile_height * raster_width * band_count * sizeof_datatype" rounded
 up to the next megabyte or so for good luck.
 > This will require changing the parser check to manual testing, but that
 shouldn't be too difficult. The default should remain at the current gdal-
 internal 40MB for low-resource users who want to import very large files.
 > for now I've put a hint in the wiki:
 >  http://grasswiki.osgeo.org/wiki/Importing_data#Large_data
 As a side note: wouldn't a memory parameter also be beneficial for
 r.out.gdal ?
 Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2171#comment:1>
