[GRASS-dev] [GRASS GIS] #2180: r.li.shannon - r.li.pielou
GRASS GIS trac at osgeo.org
Wed Jan 29 07:04:12 PST 2014
 Reporter:  matmar                     |       Owner:  grass-dev@…
     Type:  defect                     |      Status:  new
 Priority:  normal                     |   Milestone:  6.4.4
Component:  Raster                     |     Version:  unspecified
 Keywords:  r.li.shannon, r.li.pielou  |    Platform:  Linux
      Cpu:  x86-64                     |
 Hi,[[BR]]
 r.li.shannon (and consequently r.li.pielou) returns the wrong output when
 "Whole Maplayer / Select areas from the overlayed vector map" option is
 used to build the configuration file. I attached everything's needed to
 replicate the error (with r.li.shannon).
 '''example.ascii''' Simulated Landcover map.[[BR]]
 '''example_vect''' Polygon used to calculate the index.[[BR]]
 '''conf''' r.li.setup configuration file built using "Selet areas from the
 overlayed vector map" option. (Wrong shannon index).[[BR]]
 '''conf_whole_whole''' r.li.setup configuration file built using "Whole
 Maplayer / Whole Maplayer" option. (Correct Shannon index).[[BR]]
 Formula to calculate the correct Shannon index for the example landscape
 (paste it in R):
 ''-(((10/16)*log(10/16))+((2/16)*log(2/16))+((1/16)*log(1/16))+((3/16)*log(3/16)))''
 Cheers,[[BR]]
 Matteo
Ticket URL: <http://trac.osgeo.org/grass/ticket/2180>
