[GRASS-dev] [GRASS GIS] #2114: m.nviz.image does not work on Windows
GRASS GIS trac at osgeo.org
Thu Jan 30 19:58:04 PST 2014
 Reporter:  annakrat      |       Owner:  grass-dev@…
     Type:  defect        |      Status:  new
 Priority:  normal        |   Milestone:  7.0.0
Component:  LibOpenGL     |     Version:  svn-trunk
 Keywords:  m.nviz.image  |    Platform:  MSWindows 7
      Cpu:  Unspecified   |
Comment(by hamish):
 Replying to [ticket:2114 annakrat]:
 > Module m.nviz.image does not create valid image file on Windows.
 > With tif format, it crashes and with ppm it creates a file only
 > with header. So offscreen rendering doesn't seem to work.
 was the wingrass version in question built with libtiff support?
 see lib/ogsf/gsd_img_tif.c, nothing too complicated in there.
 gsd_img_ppm.c is even simpler. If header part is ok but writing the rest
 of the ppm image isn't, perhaps gsd_getimage() is returning bad values for
 xsize and ysize?
 > Has m.nviz.image ever worked on Windows?
 I don't know if anyone ever tested that; does saving as tiff or ppm from
 the G6 tcl/tk NVIZ on wingrass work?
 Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/2114#comment:1>
