[GRASS-dev] [GRASS-SVN] r60679 - grass/trunk/lib/python/script
Tue Jul 1 16:10:29 PDT 2014
Martin Landa wrote:
> beside remaining compilation errors [1], wingrass 71 still (after
> weeks!!!) even doesn't start...
Does anyone want to test the attached patch?
In particular, it needs to be tested with a Python script invoking an
exe with arguments containing characters which are likely to be
meaningful to the shell, including:
d.text or r.support may be useful as test cases.
But in the longer term, should we be claiming to support a platform
for which we appear to have no active developers?
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140702/2e3f10b2/attachment.ksh>
