[GRASS-dev] [GRASS GIS] #2360: grass startup script and wx preference file: language setting in wx does not contain country specific language code
GRASS GIS trac at osgeo.org
Sun Jul 13 00:06:04 PDT 2014
 Reporter:  mlennert     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  minor        |   Milestone:  7.0.0
Component:  Startup      |     Version:  svn-trunk
 Keywords:  locale       |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by marisn):
 I'm not certain that this is solvable at all. The set_language "magic" is
 trying to get most out of language override and gives a warning when it
 doesn't work. Seems that Python simply prefers "fr_FR" over installed
 locales. When writing the "magic", I was testing various ways how it could
 work, but, unfortunately, each of them was failing in some other way.
 The only solution for fr_BE problem would be to translate GRASS to fr_BE,
 as it has been done for pt_BR. Or come up with a cool Python hack to
 replace locale.normalize with an in-home version that prefers installed
 locales.
 As the warning affects only those users requesting language override (this
 is not a "normal" use case), I would say the warning is not a problem.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2360#comment:1>
