[GRASS-dev] GRASS 70 compilation error linux Mint 13
Anna Petrášová kratochanna at gmail.com
Wed Jul 16 06:19:16 PDT 2014
On Wed, Jul 16, 2014 at 6:30 AM, Roberto Marzocchi <
roberto.marzocchi at gmail.com> wrote:
> This is my error.log file:
> GRASS GIS 7.0.0svn r61251 compilation log
> Started compilation: mer 16 lug 2014, 11.49.02, CEST
> Errors in:
> /home/localop/Dati/source_code/grass70_release/lib/python/ctypes
> /home/localop/Dati/source_code/grass70_release/db/drivers/dbf
> /home/localop/Dati/source_code/grass70_release/db/drivers/postgres
> /home/localop/Dati/source_code/grass70_release/db/drivers/mysql
> /home/localop/Dati/source_code/grass70_release/db/drivers/sqlite
> /home/localop/Dati/source_code/grass70_release/db/drivers/ogr
> /home/localop/Dati/source_code/grass70_release/gui/wxpython/animation
> /home/localop/Dati/source_code/grass70_release/gui/wxpython/mapswipe
> /home/localop/Dati/source_code/grass70_release/gui/wxpython/gmodeler
> /home/localop/Dati/source_code/grass70_release/gui/wxpython/rlisetup
> /home/localop/Dati/source_code/grass70_release/gui/wxpython/psmap
> /home/localop/Dati/source_code/grass70_release/gui/wxpython/dbmgr
> /home/localop/Dati/source_code/grass70_release/gui/wxpython/vdigit
> /home/localop/Dati/source_code/grass70_release/gui/wxpython/iclass
> /home/localop/Dati/source_code/grass70_release/gui/wxpython/gcp
> /home/localop/Dati/source_code/grass70_release/gui/wxpython/timeline
> /home/localop/Dati/source_code/grass70_release/visualization/wximgview
> /home/localop/Dati/source_code/grass70_release/man
> In case of errors please change into the directory with error and run
> 'make'.
> If you get multiple errors, you need to deal with them in the order they
> appear in the error log. If you get an error building a library, you will
> also get errors from anything which uses the library.
> Finished compilation: mer 16 lug 2014, 11.49.56, CEST
Compilation should work as far as I know.
Could you do what the log says: please change into the directory with error
and run 'make'.
The errors might be similar for more modules (e.g. the gui or the db
modules).
Anna
> Anyone have experience with these errors?
> Thanks in advanced for the attention
> R
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140716/4d7dbc11/attachment.html>
