[GRASS-dev] [GRASS GIS] #2252: wxGUI vector digitizer passing unescaped text to database
GRASS GIS trac at osgeo.org
Thu Jul 17 13:38:16 PDT 2014
 Reporter:  marisn                                                           |       Owner:  grass-dev@…
     Type:  defect                                                           |      Status:  new
 Priority:  blocker                                                          |   Milestone:  7.0.0
Component:  wxGUI                                                            |     Version:  svn-trunk
 Keywords:  security, code injection, SQL injection, data loss, v.db.update  |    Platform:  Unspecified
      Cpu:  Unspecified                                                      |
Changes (by wenzeslaus):
  * keywords:  => security, code injection, SQL injection, data loss,
               v.db.update
Comment:
 I don't know (and quick look into source code haven't told me) what is
 used in digitizer as a backend. Library, Python SQLite API or modules?
 I've tried `v.db.update` with map `bridges` copied from `PERMANENT` and
 this was OK:
 v.db.update map=bridges column=LOCATION value="; drop database
 important_data;" where=cat=1
 String "; drop database important_data;" saved to the database.
 But this:
 v.db.update map=bridges column=LOCATION value="'; drop database
 important_data; SELECT 1='1" where=cat=1
 removed all the values from the column `LOCATION`. I'm not getting any
 error messages.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2252#comment:1>
