[GRASS-dev] [GRASS-user] os.environ['GRASS_REGION'] Error
Javier Martínez-López javi.martinez.lopez at gmail.com
Thu Jun 5 09:42:42 PDT 2014
Solved! Margherita pointed out that the original script was messing up
the values of the projection because in one of the testing versions I
was using integer values instead of characters for the region
resolution parameter, and since then the script started giving this
error, which I did not noticed. That is why it was running in one
machine and not in the other one...
This is the test script about parallel computing using different
regions [1]. I will test it and let you know if it works with a large
segmentation processing job.
Thank you very much!
Cheers,
Javier
[1] https://github.com/javimarlop/eHabpy/blob/master/pas/parallel_grass_example.py
On Thu, Jun 5, 2014 at 4:46 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Thu, Jun 5, 2014 at 10:27 AM, Javier Martínez-López
> <javi.martinez.lopez at gmail.com> wrote:
>> Hello all,
>> trying to create a temporary region within a python GRASS script using:
>> os.environ['GRASS_REGION'] = grass.region_env(res=150)
>> I get the following errors on a CentOS server:
>> ERROR: Syntax error in cell header
>> ERROR: Field <projection> missing
> What does
> g.region -p
> say in that location?
> best,
> Markus
