[GRASS-dev] G7: OGSF compilation error on Ubuntu 14.04
Markus Neteler
neteler at osgeo.org
Wed Jun 25 08:04:27 PDT 2014
I try to help to compile 7.0 on an Ubuntu box 14.04. We fail to compile OGSF:
alba at alba:~/source_code/grass70_release$ cd
/home/alba/source_code/grass70_release/lib/ogsf
alba at alba:~/source_code/grass70_release/lib/ogsf$ make
gcc -g -O2 -fPIC
-I/home/alba/source_code/grass70_release/dist.x86_64-unknown-linux-gnu/include
-I/usr/include/gdal -I/usr/include -DPACKAGE=\""grasslibs"\"
-I/usr/include/postgresql -I/usr/include/libavcodec
-I/usr/include/libavformat -I/usr/include/libswscale
-I/usr/include/libavutil
-o OBJ.x86_64-unknown-linux-gnu/GK2.o -c GK2.c
In file included from /usr/include/x86_64-linux-gnu/sys/stat.h:105:0,
from
/home/alba/source_code/grass70_release/dist.x86_64-unknown-linux-gnu/include/grass/defs/gis.h:64,
from
/home/alba/source_code/grass70_release/dist.x86_64-unknown-linux-gnu/include/grass/gis.h:636,
from GK2.c:21:
/usr/include/x86_64-linux-gnu/bits/stat.h:91:21: error: field
‘st_atim’ has incomplete type
struct timespec st_atim; /* Time of last access. */
/usr/include/x86_64-linux-gnu/bits/stat.h:92:21: error: field
‘st_mtim’ has incomplete type
struct timespec st_mtim; /* Time of last modification. */
/usr/include/x86_64-linux-gnu/bits/stat.h:93:21: error: field
‘st_ctim’ has incomplete type
struct timespec st_ctim; /* Time of last status change. */
/home/alba/source_code/grass70_release/dist.x86_64-unknown-linux-gnu/include/grass/defs/gis.h:64:0,
from
from GK2.c:21:
/usr/include/x86_64-linux-gnu/sys/stat.h:365:31: error: array type has
incomplete element type
const struct timespec __times[2],
/usr/include/x86_64-linux-gnu/sys/stat.h:372:54: error: array type has
extern int futimens (int __fd, const struct timespec __times[2]) __THROW;
make: *** [OBJ.x86_64-unknown-linux-gnu/GK2.o] Error 1
Something is overriding the time definition. I found
http://stackoverflow.com/questions/14947691/c-system-file-bits-stat-h-suddenly-breaks-with-error-field-st-atim-has-inc
but dunno what to do next.
Any Ubuntu user who knows the trick?
thanks
Markus
