[GRASS-dev] [GRASS GIS] #1825: r.tileset only returns one tile
GRASS GIS trac at osgeo.org
Mon Mar 3 13:28:34 PST 2014
 Reporter:  pvanbosgeo   |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Raster       |     Version:  svn-trunk
 Keywords:  r.tileset    |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by sbl):
 Tested in GRASS 7 revision 58670 (Ubuntu 12.04 32bit).
 On my computer it works fine both with a full proj-string ("+proj=longlat
 +datum=WGS84 +no_defs") and with the proj-string from the example from the
 manual ("+init=epsg:4326").
 However, the option "sourceproj" is case sensitive and improper projection
 strings are not caught by a user-readable error message...
Ticket URL: <http://trac.osgeo.org/grass/ticket/1825#comment:6>
