[GRASS-dev] Temporal: t.register: problem parsing when time zone present
Yann Chemin
ychemin at gmail.com
Wed Mar 5 00:48:24 PST 2014
Yes Soeren, such a pity, I missed all your temporal fun!
As usual, have to do it the hard way...
Thanks,
I will set up the input file, inefficient, but my data is not regular in
time...
On 5 March 2014 14:15, Sören Gebbert <soerengebbert at googlemail.com> wrote:
> Hi,
> such a pity you were not in the TGIS workshop.
> However, there can be gaps between time intervals.
> Hence the end time of a time interval can be start time of a potential
> successor or the start time of a gap.
> But gaps are not stored explicitly, they are computed by topological
> analysis
> I would suggest that you create an input text file that lists all maps
> with time stamps that should be registered
> If you call t.register for each single map the registration will be
> very inefficient and slow
> Example of an input file with gaps between map intervals:
> mapA|2001-05-10|2001-05-11
> mapB|2001-05-15|2001-05-16
> Best regards
> Soeren
> 2014-03-05 9:29 GMT+01:00 Yann Chemin <ychemin at gmail.com>:
> > Thank you Soeren,
> > If I want to register an irregular set of daily maps (missing days), will
> > the end date need to be the next day (say 5 days after this image, 2 days
> > after in the next image)?
> > Cheers,
> > Yann
> > On 5 March 2014 12:14, Sören Gebbert <soerengebbert at googlemail.com>
> wrote:
> >> Hi Yann,
> >> if you need support for time zones you have to use postgresql as
> >> backend. Unfortunately sqlite does not support time zones. A work
> >> around would be to ignore the time zone and use t.shift to temporally
> >> shift the created STRDS by 5h and 30 min to UTC time after registering
> >> the maps. I should notice this in the help page, i don't know why i
> >> missed that ..???!!!
> >> The next thing is that TGRASS uses time intervals in which the end
> >> time is not part of the time interval, but the start time of a
> >> successor. That means that you do not need to know how many days in a
> >> month are; Interval of one day: start="2004-05-10" end="2004-05-11"
> >> Best regards
> >> Soeren
> >> 2014-03-05 6:36 GMT+01:00 Yann Chemin <ychemin at gmail.com>:
> >> > Hi,
> >> > input line is:
> >> > t.register input=ta maps=ta_2004131 start="2004-05-10 00:00:00 +0530"
> >> > end="2004
> >> > -05-10 23:59:59 +0530"
> >> > temporal says:
> >> > File "/usr/lib/python2.7/sqlite3/dbapi2.py", line 69, in
> >> > convert_timestamp
> >> > hours, minutes, seconds = map(int, timepart_full[0].split(":"))
> >> > ValueError: invalid literal for int() with base 10: '00+05'
> >> > Manual says following format accepted:
> >> > start=string
> >> > Valid start date and time of the first map. Format absolute time:
> >> > "yyyy-mm-dd HH:MM:SS +HHMM", relative time is of type integer).
> >> > end=string
> >> > Valid end date and time of all map. Format absolute time: "yyyy-mm-dd
> >> > yann
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140305/d7d0297f/attachment.html>
