[GRASS-dev] [GRASS GIS] #2209: r.ros fails with -s flag with invalid descriptor error
GRASS GIS trac at osgeo.org
Tue Mar 11 07:16:03 PDT 2014
  Reporter:  wenzeslaus  |       Owner:  grass-dev@…
      Type:  defect      |      Status:  closed
  Priority:  minor       |   Milestone:  7.0.0
 Component:  Raster      |     Version:  svn-trunk
Resolution:  fixed       |    Keywords:
  Platform:  Linux       |         Cpu:  Unspecified
Changes (by wenzeslaus):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Thanks and wow, I expected something more complicated then repeated line.
 It works now. Tested with
 r.ros -s model=fuel_model moisture_1h=1hour_moisture
 moisture_live=live_moisture velocity=wind_speed direction=wind_direction
 slope=slope aspect=aspect elevation=elevation output=my_ros --verbose
 r.spread -s max=my_ros.max base=my_ros.base dir=my_ros.maxdir
 spot_dist=my_ros.spotdist w_speed=wind_speed f_mois=1hour_moisture
 start=fire_origin lag=95 backdrop=image_burned output=my_spread
 x_output=my_spread.x y_output=my_spread.y
 with sample fire simulation data (http://grass.osgeo.org/download/sample-
 data/) in trunk.
 No error message obtained. Maps generated.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2209#comment:2>
