[GRASS-dev] [GRASS GIS] #2216: Location wizard fails on EPSG 3049
GRASS GIS trac at osgeo.org
Wed Mar 12 02:44:37 PDT 2014
 Reporter:  marisn       |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  major        |   Milestone:  7.0.0
Component:  Startup      |     Version:  svn-trunk
 Keywords:               |    Platform:  Unspecified
      Cpu:  Unspecified  |
Comment(by neteler):
 Here it works fine - also from command line (using PROJ.4 V4.8.0):
 grass70 -c epsg:3049 ~/grassdata/testlocation
 GRASS 7.0.svn (testlocation):~ > g.proj -w
 PROJCS["UTM Zone 37, Northern Hemisphere",
     GEOGCS["grs80",
         DATUM["European_Terrestrial_Reference_System_1989",
 SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101]],
         PRIMEM["Greenwich",0],
         UNIT["degree",0.0174532925199433]],
     PROJECTION["Transverse_Mercator"],
     PARAMETER["latitude_of_origin",0],
     PARAMETER["central_meridian",39],
     PARAMETER["scale_factor",0.9996],
     PARAMETER["false_easting",500000],
     PARAMETER["false_northing",0],
     UNIT["Meter",1]]
 GRASS 7.0.svn (testlocation):~ > g.version -e
 GRASS 7.0.svn (2014)
 PROJ.4: 4.8.0
 GDAL/OGR: 1.10.1
 GRASS not compiled with GEOS support
 SQLite: 3.8.3
 Maris, which PROJ4 version do you use?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2216#comment:1>
