[GRASS-dev] g.mremove: adding 'map name exclusion pattern' option
Vaclav Petras wenzeslaus at gmail.com
Mon Mar 24 11:04:00 PDT 2014
Hi Paulo,
There was no response in 5 days, you should create ticket for this,
otherwise we will forgot about it. I'm just adding some notes here.
On Wed, Mar 19, 2014 at 7:14 AM, Paulo van Breugel
<p.vanbreugel at gmail.com>wrote:
>  Hi,
> Would it be difficult to add an option to use 'map name exclusion
> patterns' like is available in g.mlist?
I'm always very confused when switching between g.mlist and g.mremove. The
parameters are almost the same, yet different.
g.mlist type=rast pattern="tmp_*"
g.mremove rast="tmp_*"
>  In the meantime, is it possible to exclude maps using regular expression
> in g.mremove?
> Not sure, regular expressions are very bad at negative expressions/matches.
Vaclav
 Best
> Paulo
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140324/af5c8a77/attachment.html>
