[GRASS-dev] [GRASS GIS] #1418: v.dissolve not working
GRASS GIS trac at osgeo.org
Wed Mar 26 09:00:46 PDT 2014
 Reporter:  hellik  |       Owner:  grass-dev@…
     Type:  defect  |      Status:  new
 Priority:  major   |   Milestone:  7.0.0
Component:  Vector  |     Version:  svn-trunk
 Keywords:          |    Platform:  All
      Cpu:  All     |
Comment(by martinl):
 Replying to [comment:3 neteler]:
 > v.dissolve also silently fails on Linux as no effect is taken on the
 resulting map (also, one less area than in GRASS 6.4.svn):
 when you don't defined 'column' option, features are dissolved based on
 category. I have added warning about that in r59375.
 > North Carolina dataset:
 > GRASS 6.4.2svn (nc_spm_08):~ > v.dissolve zipcodes_wake out=zip_name
 > Number of areas: 27
 > Number of isles: 2
 > -> 48 areas reduced to 27 areas, look ok but:
 this is probably typo I am getting 47 areas also in G6, you probably
 missed `column=ZIPNAME`. It seems to me that there is no difference in
 results produced in G6 or G7.
 G6 & G7:
 v.dissolve in=zipcodes_wake out=zip_names --o -> 47
 v.dissolve in=zipcodes_wake out=zip_names --o column=ZIPNAME -> 27
Ticket URL: <http://trac.osgeo.org/grass/ticket/1418#comment:6>
