[GRASS-dev] wingrass71: rendering problems with raster layers automatically added by finished modules
Helmut Kudrnovsky hellik at web.de
Sat May 3 13:15:38 PDT 2014
tested with winGRASS71 by osgeo4w from today.
Rendering is activated in map display.
start e.g. r.slope.aspect in the wxgui, define more than one outputs.
Automatically adding the results to map display is activated.
run r.slope.aspect, after the output results are added to map display,
rendering has problems.
-erase map display erases display, but rendering again raster artefacts are
displayed
- change raster color, raster artefacts are displayed
-only after deleting from and readding result raster in map display,
rendering is correct.
anyone confirms this behavior?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/wingrass71-rendering-problems-with-raster-layers-automatically-added-by-finished-modules-tp5138427.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
