[GRASS-dev] grass7/0_trunk/release fail to start
Nikos Alexandris nik at nikosalexandris.net
Thu May 8 14:26:33 PDT 2014
On 08.05.2014 11:56, Nikos Alexandris wrote:
> # in grass70_release directory
> make distclean
> ./configure --with-freetype-includes="/usr/include/freetype2/"
> # compile
> make -j5
> Errors in:
> No errors detected.
> # launch grass
> /osgeo/grass70_release/bin.x86_64-unknown-linux-gnu $ ./grass70
> /geo/grassdb/wgs84/PERMANENT/
> Starting GRASS GIS...
> Traceback (most recent call last):
>   File "./grass70", line 1386, in <module>
>     check_lock()
>   File "./grass70", line 857, in check_lock
>     ret = call([gfile("etc", "lock"), lockfile, "%d" % os.getpid()])
>   File "./grass70", line 154, in call
>     return subprocess.call(cmd, **kwargs)
>   File "/usr/lib64/python2.7/subprocess.py", line 522, in call
>     return Popen(*popenargs, **kwargs).wait()
>   File "/usr/lib64/python2.7/subprocess.py", line 709, in __init__
>     errread, errwrite)
>   File "/usr/lib64/python2.7/subprocess.py", line 1326, in
> _execute_child
>     raise child_exception
> OSError: [Errno 2] No such file or directory
> Same error again.  I must have something wrong with my local
> configuration (all this in a new machine).  In my other Funtoo-box, I
> don't remember having done something differently. For example, I
> didn't need to setup anything in ld.so.conf.
Could it be due to a difference in wxPython installations?  In the
working machine I have version 2.9.4.1-r2  and in the faulty one
3.0.0.0?  But this shouldn't be a problem, right?  The Requirements say:
"wxPython >= 2.8.10.1".
Thanks, Nikos
