[GRASS-dev] grass7/0_trunk/release fail to start
Nikos Alexandris nik at nikosalexandris.net
Fri May 9 02:55:34 PDT 2014
On 09.05.2014 00:31, Markus Neteler wrote:
> On Thu, May 8, 2014 at 11:26 PM, Nikos Alexandris
> <nik at nikosalexandris.net> wrote:
>> Could it be due to a difference in wxPython installations?  In the
>> working
>> machine I have version 2.9.4.1-r2  and in the faulty one 3.0.0.0?
>> But this
>> shouldn't be a problem, right?  The Requirements say: "wxPython >=
>> 2.8.10.1".
> Mhh, probably yes? While I commonly use Python 2.x I enforced python3
> use for a test:
> [neteler at oboe init]$ export GRASS_PYTHON=python3
> [neteler at oboe init]$ grass70 -gui
> Cleaning up temporary files...
> Starting GRASS GIS...
>   File
> "/home/neteler/software/grass70_release/dist.x86_64-unknown-linux-gnu/gui/wxpython/gis_set.py",
> line 409
>     except ValueError, e:
> SyntaxError: invalid syntax
> Error in GUI startup. If necessary, please report this error to the
> GRASS developers.
> Switching to text mode now.
> Using:
> python3 --version
> Python 3.3.2
> So it seems to make a difference.
It would here too, but I am referring to wxPython and not Python.  In
both systems there is:
$ eselect python list
Available Python interpreters:
   [1]   python2.7 *
   [2]   python3.3
I also installed wxPython 2.9.4.1-r2 in the "faulty" box, so both
systems do have:
$ eselect wxwidgets list
Available wxWidgets profiles:
   [1]   gtk2-unicode-2.9 *
I recompiled but it didn't help :-(.  I will search for Gentoo/Funtoo
support elsewhere than here.  Thank you Markus,
Nikos
