[GRASS-dev] GRASS created geotiff do not properly load into PostGIS (raster2pgsql)
Blumentrath, Stefan Stefan.Blumentrath at nina.no
Fri May 16 05:31:37 PDT 2014
Thanks Rémi,
For clarification. The remaining question is, is this a PostGIS or a GRASS issue?
Since GRASS and GDAL obviously manage to handle the NaN concept, maybe raster2pgsql should be able to do that too?
Cheers
Stefan
Sent: 16. mai 2014 14:15
To: Blumentrath, Stefan
Cc: GRASS developers list (grass-dev at lists.osgeo.org); postgis-devel at lists.osgeo.org
Subject: Re: [GRASS-dev] GRASS created geotiff do not properly load into PostGIS (raster2pgsql)
OK gdal is out of the way.
Like you I had troubles with the 'nan' value ,
because 'nan' is actually platform dependent AND it get casted differently depending on the precision of the type.
Like you said the only way to get it working was manually assign a number instead of Nan :-(
Cheers,
Rémi-C
2014-05-16 11:40 GMT+02:00 Blumentrath, Stefan <Stefan.Blumentrath at nina.no<mailto:Stefan.Blumentrath at nina.no>>:
And thanks for the swift response!
My GDAL version is:
GDAL 1.11.0, released 2014/04/16.
I recompiled GDAL recently (but not PostGIS). Can that be the source of error?
However, ASCII and Tiffs with assigned NoData work…
Cheers
Stefan
From: Rémi Cura [mailto:remi.cura at gmail.com<mailto:remi.cura at gmail.com>]
Sent: 16. mai 2014 11:24
Cc: GRASS developers list (grass-dev at lists.osgeo.org<mailto:grass-dev at lists.osgeo.org>); postgis-devel at lists.osgeo.org<mailto:postgis-devel at lists.osgeo.org>
Hey,
what is your version of gdal (type `gdalinfo --version`)
Cheers,
Rémi-C
2014-05-16 11:14 GMT+02:00 Blumentrath, Stefan <Stefan.Blumentrath at nina.no<mailto:Stefan.Blumentrath at nina.no>>:
And sorry for posting on two lists. Just don`t know where the issue belongs to…
I tried to load a set of raster maps in Geotiff format, which I created in GRASS using r.external.out, into PostGIS 2.1.2dev.
In PostGIS the raster datasets only contain NoData values, while gdalinfo –stats produces reasonable statistics for the respective GeoTiffs.
I did some trouble shooting and found that the problem was that GRASS did not assign a numerical NoData value to the GeoTiff, but “nan”.
When I gdal_translate same GeoTiff with –a_nodata -9999, raster2pgsql loads the resulting file just fine.
Is raster2pgsql supposed to read rasters with nan as NoData values (using –N -9999 in raster2pgsql had no effect btw.) or should GRASS (r.external.out) assign a NoData value to the produced raster datasets?
Many thanks in advance,
Stefan
grass-dev mailing list
http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140516/dd25a89f/attachment-0001.html>
