[GRASS-dev] wxGUI customized toolboxes: handler for non-GRASS commands
Anna Petrášová kratochanna at gmail.com
Sun May 18 06:20:15 PDT 2014
Hi Yann,
On Sat, May 17, 2014 at 11:46 PM, Yann Chemin <ychemin at gmail.com> wrote:
> Hi Anna,
> Patch works great ! Needs RunMenuCmd and all goes to perfection. Any
> chance to have it included in the SVN tree?
I committed the patch in trunk, if you agree, I won't backport it now. I
don't understand what do you mean with RunMenuCmd, is there still some
problem and what is it exactly?
Anna
Thank you
> Yann
> On 18/05/2014, Anna Petrášová <kratochanna at gmail.com> wrote:
> > Hi Yann,
> > it's grayed out because it tests if it's a working grass command (for
> > example r.in.lidar is grayed when you don't compile grass with liblas).
> You
> > can try to apply this patch which tests if the command looks like grass
> > command (regular expression) and if it is not, it doesn't disable it in
> > menu.
> > Index: gui_core/menu.py
> > --- gui_core/menu.py (revision 60284)
> > +++ gui_core/menu.py (working copy)
> > @@ -18,7 +18,7 @@
> >  @author Robert Szczepanek (menu customization)
> >  @author Vaclav Petras <wenzeslaus gmail.com> (menu customization)
> > +import re
> >  import wx
> >  from core              import globalvar
> > @@ -91,7 +91,8 @@
> >                  cmd = utils.split(str(command))
> >              except UnicodeError:
> >                  cmd = utils.split(EncodeString((command)))
> > -            if cmd and cmd[0] not in globalvar.grassCmd:
> > +            if cmd and cmd[0] not in globalvar.grassCmd and \
> > +               re.match('[rvdipmgt][3bs]?\.([a-z0-9\.])+', cmd[0]):
> >                  menuItem.Enable(False)
> >          rhandler = eval('self.parent.' + handler)
> > On Fri, May 16, 2014 at 12:30 AM, Yann Chemin <ychemin at gmail.com> wrote:
> >> in svn/gui/wxpython/lmgr/frame.py
> >> line 758
> >> by adding:
> >>     def RunCmd(self, event = None, cmd = []):
> >>         """!Run command to system from menu"""
> >>         if event:
> >>             cmd = self.GetMenuCmd(event)
> >>         os.system(cmd)
> > I am not sure if this is needed. I would say it might work without this
> > change but you have to try it out.
> > Best,
> > Anna
> >> it should handle it, however, it seems that a flag is needed to enable
> >> the possibility to click the command from the created menu. It is
> >> still grey/shadowed.
> >> On 16/05/2014, Yann Chemin <ychemin at gmail.com> wrote:
> >> > To be precise, the non-GRASS programs have their own GUI already, and
> >> > the calls need only one word.
> >> >> Hi,
> >> >> I would like to make a customized toolbox to call some non-GRASS CLI
> >> >> programs.
> >> >> Handlers OnMenuCmd and RunMenuCmd seem not to work. The menu items
> are
> >> >> grey/shadowed so that no mouse click is allowed on them.
> >> >> thanks
> >> >> Yann
> >> _______________________________________________
> >> grass-dev mailing list
> >> grass-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140518/ce6e4f4a/attachment.html>
