[GRASS-dev] [GRASS-user] execGRASS("r.diversity"): [Error 3] Cannot find path specified \\.grass7\\r.li
Wed May 21 10:38:50 PDT 2014
[CC to grass-dev]
Sandra MacFadyen wrote:
>   File "C:/Program Files (x86)/GRASS GIS 7.0.0beta2/scripts/r.diversity.py",
> line 116, in main
>     os.mkdir(rlidir)
> WindowsError: [Error 3] The system cannot find the path specified:
> 'D:/Bands_processed1\\.grass7\\r.li'
r.diversity.py is broken on Windows:
    home = os.path.expanduser('~')
    rlidir = os.path.join(home, '.grass7', 'r.li')
The script tries to create an r.li subdirectory, but fails because the
parent directory doesn't exist.
$HOME/.grass7 is correct for Unix, but on Windows it's
%APPDATA%\GRASS7. From lib/init/grass.py:
    # configuration directory
    grass_env_file = None  # see check_shell()
    if sys.platform == 'win32':
        grass_config_dirname = "GRASS7"
        grass_config_dir = os.path.join(os.getenv('APPDATA'), grass_config_dirname)
    else:
        grass_config_dirname = ".grass7"
        grass_config_dir = os.path.join(os.getenv('HOME'), grass_config_dirname)
