[GRASS-dev] g.mlist list multiple types from all mapsets
Huidae Cho grass4u at gmail.com
Sun May 25 04:45:52 PDT 2014
Martin,
g.mlist already has -t flag for printing element types.
rast/x at g6
vect/b at g6
vect/obce6 at g6
vect/kltm50 at PERMANENT
Regarding all mapsets search, it should be (1) because a new flag for all
mapsets & mapset=. (default for the current mapset) have a conflict meaning
and can be confusing. Maybe, mapset=- (minus)?
Curious why we need all mapsets search..
Huidae
On Sun, May 25, 2014 at 3:43 AM, Martin Landa <landa.martin at gmail.com>wrote:
> Hi all,
> I would like to modify `g.mlist` to enable listing multiple types from
> all mapsets in the given location. Now you can list multiple types
> from search path, ie.
> $ g.mlist rast,vect -m
> raster map(s) available in mapset <g6>:
> x at g6
> vector map(s) available in mapset <g6>:
> b at g6
> obce6 at g6
> vector map(s) available in mapset <PERMANENT>:
> kltm50 at PERMANENT
> lesy at PERMANENT
> merene_body at PERMANENT
> obce at PERMANENT
> obce_b at PERMANENT
> orp at PERMANENT
> zel_stan at PERMANENT
> zelez at PERMANENT
> but it's hardly parsable
> $ g.mlist rast,vect -m --q
> x at g6
> b at g6
> obce6 at g6
> kltm50 at PERMANENT
> lesy at PERMANENT
> obce at PERMANENT
> obce_b at PERMANENT
> orp at PERMANENT
> zelez at PERMANENT
> so I was thinking to add a new flag which prints also element type
> rast x at g6
> vect b at g6
> vect obce6 at g6
> vect kltm50 at PERMANENT
> (do we really need a new flag for that? There is probably nobody who
> is parsing multiple types from `g.mlist`. So probably element type
> could be automatically printed when mutiple types and `--q` flag are
> given (?) Maybe too tricky...
> The remaining question how to implement all mapsets search.
> mapset=.
> means search path
> 1) do we introduce special character for all mapsets ? (preferable I would
> say)
> 2) do we introduce new flag ?
> Thanks for your ideas in advance! Martin
> Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140525/ca5c5f45/attachment.html>
