[GRASS-dev] g.mlist list multiple types from all mapsets
Huidae Cho grass4u at gmail.com
Sun May 25 07:01:28 PDT 2014
More recent discussion about g.mremove at
http://lists.osgeo.org/pipermail/grass-dev/2014-May/068774.html
As I mentioned in the above thread, I prefer the g.mlist interface because
it's easier to add more types and the exclude parameter.
I thought about the "all" mapset special character. ".." would be more
logical than "-" because it means go up to the current location and list
all mapsets under it.
On May 25, 2014 9:32 AM, "Vaclav Petras" <wenzeslaus at gmail.com> wrote:
> On Sun, May 25, 2014 at 3:43 AM, Martin Landa <landa.martin at gmail.com>wrote:
>> I would like to modify `g.mlist` to enable listing multiple types from
>> all mapsets in the given location. Now you can list multiple types
>> from search path, ie.
> This is just a reminder of recent discussions about g.mlist and g.mremove.
> It seems that we want a lot of changes in them.
> g.mlist warnings for layers found in other mapsets
> http://trac.osgeo.org/grass/ticket/2255
> g.list and g.mlist should be able to handle strds, str3ds, stvds
> http://trac.osgeo.org/grass/ticket/2266
> g.mremove: adding 'map name exclusion pattern' option
> http://lists.osgeo.org/pipermail/grass-dev/2014-March/067800.html
> g.mremove: add an option to use 'map name exclusion patterns' like is
> available in g.mlist
> http://trac.osgeo.org/grass/ticket/2228
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140525/2707c7a3/attachment.html>
