[GRASS-dev] [GRASS GIS] #2314: output r.out.xyz
GRASS GIS trac at osgeo.org
Fri May 30 21:55:04 PDT 2014
 Reporter:  pvanbosgeo                           |       Owner:  grass-dev@…
     Type:  defect                               |      Status:  new
 Priority:  normal                               |   Milestone:  7.0.0
Component:  Default                              |     Version:  svn-trunk
 Keywords:  separator, pipe, r.out.xyz, r.stats  |    Platform:  MSWindows 7
      Cpu:  All                                  |
Comment(by glynn):
 Replying to [comment:12 annakrat]:
 > It's not problem of wxGUI but maybe of Python scripting library. Today's
 version of r.out.xyz on Windows gives this error when you specify | or you
 leave default:
 The syntax of the command is incorrect.
 How are you running the script?
 If it isn't via cmd.exe in a console window, with parameters provided on
 the command line, then that's the first thing to try. Any problems when
 executing via wxGUI or using the parameter dialogs should be assumed to be
 problems with those features until proven otherwise.
 > Adding quotes around pipe (for example in ```_make_val``` function in
 grass.core) works but results in ```"|"``` as a separator (3 characters)
 which is wrong. So, now we have r.out.xyz broken on Windows. Any ideas?
 If a command is executed via e.g. grass.run_command(), Python's
 subprocess.Popen() provides the necessary quoting.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2314#comment:15>
