[GRASS-dev] [GRASS GIS] #2314: output r.out.xyz
GRASS GIS trac at osgeo.org
Sat May 31 07:37:20 PDT 2014
 Reporter:  pvanbosgeo                           |       Owner:  grass-dev@…
     Type:  defect                               |      Status:  new
 Priority:  normal                               |   Milestone:  7.0.0
Component:  Default                              |     Version:  svn-trunk
 Keywords:  separator, pipe, r.out.xyz, r.stats  |    Platform:  MSWindows 7
      Cpu:  All                                  |
Comment(by wenzeslaus):
 Replying to [comment:19 hcho]:
 > I replied to the last email, but it doesn't appear here. Reposting..
 Things from here are send also to grass-dev but from grass-dev nothing
 goes here.
 > Check r60634. ^|& had to be escaped with ^^^. I tested it on Windows 7
 and it works.
 > Check r60634. `^|&` had to be escaped with `^^^`. I tested it on Windows
 7 and it works.
 You need to use backtics {{{`something`}}} or tree curly brackets
 `{{{something}}}`.
 Can you provide your testing examples? I can try to create a test from
 them.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2314#comment:22>
