[GRASS-dev] Empty record in gselect.Select
Anna Petrášová kratochanna at gmail.com
Tue Nov 4 07:51:53 PST 2014
On Tue, Nov 4, 2014 at 8:53 AM, Luca Delucchi <lucadeluge at gmail.com> wrote:
> Hi devs,
> For g.gui.rlisetup I need an empty record or an empty string in
> gselect.Select. I would like add a variable in the__init__ function to add
> automatically the empty record to the list.
> Is there any other way how to assign an empty value to gselect.Select?
> Ciao
> Luca
> Hm, why would you need an empty record? Can't you just leave the field
empty? Could you maybe better describe what exactly you want to do?
Anna
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141104/38bfcb77/attachment.html>
