[GRASS-dev] Issues installing GRASS 7.0 from Ubuntu PPA
Vaclav Petras wenzeslaus at gmail.com
Wed Nov 19 18:52:41 PST 2014
On Wed, Nov 19, 2014 at 7:36 PM, Isaac Ullah <isaac.ullah at asu.edu> wrote:
> Sorry, premature send! Here's the error message:
> Launching <wxpython> GUI in the background, please wait...
> [Raster MASK present]
> GRASS 7.0.0 (Exp3):~ > Traceback (most recent call last):
>   File "/usr/lib/grass70/gui/wxpython/wxgui.py", line 140, in <module>
>     sys.exit(main())
>   File "/usr/lib/grass70/gui/wxpython/wxgui.py", line 133, in main
>     app = GMApp(workspaceFile)
>   File "/usr/lib/grass70/gui/wxpython/wxgui.py", line 48, in __init__
>     wx.App.__init__(self, False)
>   File "/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode/wx/_core.py",
> line 7981, in __init__
>     self._BootstrapApp()
> line 7555, in _BootstrapApp
>     return _core_.PyApp__BootstrapApp(*args, **kwargs)
>   File "/usr/lib/grass70/gui/wxpython/wxgui.py", line 82, in OnInit
>     workspace = self.workspaceFile)
>   File "/usr/lib/grass70/gui/wxpython/lmgr/frame.py", line 93, in __init__
>     grassVersion = grass.version()['version']
>   File "/usr/lib/grass70/etc/python/grass/script/core.py", line 1467, in
> version
>     data = parse_command('g.version', flags='rge')
>   File "/usr/lib/grass70/etc/python/grass/script/core.py", line 465, in
> parse_command
>     res = read_command(*args, **kwargs)
>   File "/usr/lib/grass70/etc/python/grass/script/core.py", line 425, in
> read_command
>     return handle_errors(returncode, stdout, args, kwargs)
>   File "/usr/lib/grass70/etc/python/grass/script/core.py", line 308, in
> handle_errors
>     returncode=returncode)
> grass.exceptions.CalledModuleError: Module run None ['g.version', '-rge']
> ended with error
> Process ended with non-zero return code -11. See errors in the (error)
> output.
This relates to problems with g.version (#2351) and new, more strict error
handling (#2326). I tried to fix g.version in r61589 but I'm not sure if I
was successful, now it seems that I was not. I'm also not sure what r62747
changed in g.version checks. (Note: Both changes are backported to release
branch 7.0.)
At least the error handling now gives us the idea about what's happening.
-11 means segmentation fault on Ubuntu AFAIK, so it is really related to
#2351.
I changed the error handling to "ignore" in r62822 (and backported). It
reintroduces the original behavior before #2326. Although it might be
appropriate in this case, the better solution would be to fix g.version as
r61589 was trying to do.
https://trac.osgeo.org/grass/ticket/2351
https://trac.osgeo.org/grass/ticket/2326
https://trac.osgeo.org/grass/changeset/61589 (
https://trac.osgeo.org/grass/changeset/61683)
https://trac.osgeo.org/grass/changeset/62747 (
https://trac.osgeo.org/grass/changeset/62748)
https://trac.osgeo.org/grass/changeset/62822 (
https://trac.osgeo.org/grass/changeset/62823)
> I still have a GRASS session in the terminal, and can run some grass
> commands, but not others. For example, "g.region -p" is fine, but
> "g.mremove" give the following error:
> g.mremove: command not found
> Note that g.mremove was recently replaced g.remove. See Trac wiki for
details:
https://trac.osgeo.org/grass/wiki/Grass7/NewFeatures#Renamedmodules
> The strange thing is that about a month ago, I was able to install a
> perfectly working version of GRASS7 on a similar computer with no issues
> (other than the apparently ineffectual error with g.version). I've tried
> this on three separate computers, and all have the same problem. I've tried
> installing all the dev packages I could think of (for example, all wx
> python dev libraries), but nothing seems to help.
> Any ideas what's going on? What can I do?
> There is something strange happening with packaging, the self-compiled
version does not suffer from g.version issues.
Vaclav
~Isaac
> On Wed, Nov 19, 2014 at 5:30 PM, Isaac Ullah <isaac.ullah at asu.edu> wrote:
>> Hi all,
>>    I've been trying to get GRASS7 installed on several machines running
>> Xubuntu 14.04, with no success. These are fresh installs of the OS, so
>> there should be no cruft complicating install. I'm installing from the
>> "GRASS-stable" ubuntu PPA repository, and am indeed following all the
>> procedures. GRASS seems to install okay, but there are major issues when I
>> try to run it. First, wx-gui dies on start with the following error message:
>> Isaac I Ullah, Ph.D.
>> Arizona State University
>> School of Human Evolution and Social Change
>> PO Box 2402
>> Tempe, AZ 85287-2402
>> (480) 727-1054 office
>> (650) 201-0479 cell
>> iullah at asu.edu
> PO Box 2402
> (650) 201-0479 cell
> iullah at asu.edu
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141119/d4a6ac56/attachment-0001.html>
