[GRASS-dev] [GRASS GIS] #2409: last call for options keys consolidation
Sat Nov 29 13:58:08 PST 2014
Anna Petrášová wrote:
> What about r.stats using uppercase flags:
> -A Print averaged values instead of intervals (floating-point maps only)
> -N Do not report cells where all maps have no data
> -C Report for cats floating-point ranges (floating-point maps only)
This isn't so much of an issue. As flags are limited to a single
character, there are fewer choices available. Modules with many flags,
would end up having to use almost entirely arbitrary flag names once
the first, second, third, ... choices were already taken.
