[GRASS-dev] SVN trunk issue with g.list and g.remove (and solution)
Huidae Cho grass4u at gmail.com
Thu Oct 2 07:22:50 PDT 2014
On Wed, Oct 01, 2014 at 05:49:08PM -0400, Vaclav Petras wrote:
>    On Wed, Oct 1, 2014 at 4:43 PM, Markus Metz
>    <[1]markus.metz.giswork at gmail.com> wrote:
>      On Tue, Sep 30, 2014 at 8:16 PM, Huidae Cho <[2]grass4u at gmail.com>
>      wrote:
>      > Hmm... I "remove"d g.list/g.remove and "rename"d
>      g.mlist/g.mremove. Maybe,
>      > there is a better way?
>      Did you "remove" or "svn remove"? Same for "rename". I guess you did
>      "svn [remove|rename]", and some other people did not "make
>      distclean"
>      before "svn up". FWIW, I had no problems with your changes, doing
>      "make distclean" before "svn up".
>      Whoever compiles GRASS from source and wants the latest and greatest
>      (svn up), must clean the source code first with "make distclean"
>      before recompiling. This applies to all 4 branches. This is not
>      GRASS
>      specific but the way how svn works.
>    make distclean or just make clean, this might be it. The message from
>    SVN was not much helpful, although it changed from the previous
>    version.
>    But usually you don't have to do make *clean, so how to know these
>    things ahead (except for looking at Trac)? I don't know. Or is there
>    some option in SVN (from the options you are given) to use "theirs all"
>    as it was in previous SVN version (I don't know which)?
I guess that when you "svn up", it doesn't clean the OBJ directory in
the old g.list/g.remove directories and old object files conflict with
the new source files?
Huidae
>      Markus M
>    > On Tue, Sep 30, 2014 at 1:19 PM, Vaclav Petras
>    <[3]wenzeslaus at gmail.com> wrote:
>    >> On Tue, Sep 30, 2014 at 12:02 PM, Markus Neteler
>    <[4]neteler at osgeo.org>
>    >> wrote:
>    >>> On Tue, Sep 30, 2014 at 5:25 PM, Vaclav Petras
>    <[5]wenzeslaus at gmail.com>
>    >>> wrote:
>    >>> > Confirmed, I had to do the same in all copies too some time ago.
>    SVN is
>    >>> > not
>    >>> > really good at renaming and deleting things, it is always
>    confused and
>    >>> > I
>    >>> > really don't understand why I need to do revert.
>    >>> As this almost never happened, it may have been this specific
>    commit
>    >>> being different from others.
>    >>> Whatever, the solution we have.
>    >> Oh, now I hope it was not because I recommended some Git-like
>    procedure to
>    >> Huidae which is not really what SVN wanted. Anyway, it was easy to
>    solve
>    >> although it required manual intervention to automatic builds (at
>    least the
>    >> one for tests).
>    >>> Markus
>    >> _______________________________________________
>    >> grass-dev mailing list
>    >> [6]grass-dev at lists.osgeo.org
>    >> [7]http://lists.osgeo.org/mailman/listinfo/grass-dev
>    > [8]grass-dev at lists.osgeo.org
>    > [9]http://lists.osgeo.org/mailman/listinfo/grass-dev
> References
>    1. mailto:markus.metz.giswork at gmail.com
>    2. mailto:grass4u at gmail.com
>    3. mailto:wenzeslaus at gmail.com
>    4. mailto:neteler at osgeo.org
>    5. mailto:wenzeslaus at gmail.com
>    6. mailto:grass-dev at lists.osgeo.org
>    7. http://lists.osgeo.org/mailman/listinfo/grass-dev
>    8. mailto:grass-dev at lists.osgeo.org
>    9. http://lists.osgeo.org/mailman/listinfo/grass-dev
