[GRASS-dev] Issues with Sphinx on osgeo server
Vaclav Petras wenzeslaus at gmail.com
Sat Oct 4 21:04:01 PDT 2014
On Sat, Oct 4, 2014 at 5:53 PM, Sören Gebbert <soerengebbert at googlemail.com>
wrote:
> Hi,
> i have the same problem on Ubuntu 12.04. The documentation for the
> wxgui failed to build with a shell error.
> Which error exactly, the same error as Markus had? Are you able to test it
more?
In fact, it seems to me that there were 3 different error states which
Markus reported. First, Sphinx documentation was running, wxgui was perhaps
successful (at least it did not stopped the build) but unfortunately it
failed and we don't have the full log, so we don't know what was caused the
fail. Second state were when Sphinx build started but ended at the very
beginning in conf.py with not being able to import grass.script package
(which means that PYTHONPATH/sys.path was wring or GRASS not build or ?).
The third is the most strange one and this is the one with no value for
sphinx build variable which should fail at different place or not at all
(and the later should be the case since sphinx is generally running).
> As a workaround (and to save time building the library docs) i added
> "make sphinxdoclib" to the GRASS make system, so that only the python
> library documentation is build. This includes the source code
> documentation as well.
> The documentation at:
> http://grass.osgeo.org/grass71/manuals/libpython/
> lacks the source code doc links in the library documentation which are
> important.
> Hopefully will "make sphinxdoclib" fix this on the server.
> Best regards
> Soeren
> 2014-10-04 23:32 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
> > On Sat, Oct 4, 2014 at 10:31 PM, Markus Neteler <neteler at osgeo.org>
> wrote:
> >> # generate pyGRASS sphinx manual (in docs/html/libpython/)
> >> (cd lib/python/docs/ ; make libpythonhtml)
> >> --> works ok
> >> # generate wxGUI sphinx manual etc, (in main src directory)
> >> make sphinxdoc
> >> --> fails (also on Fedora):
> > I have updated the cronjob and continue to use
> > The sphinx based docs are back now:
> > - PyGRASS documentation
> > - The GRASS GIS Temporal Framework
> > - Testing GRASS GIS source code and modules
> > cheers
> > Markus
> > grass-dev mailing list
> > grass-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141005/5314c916/attachment.html>
