[GRASS-dev] [GRASS GIS] #2152: cd command does not work in GUI Command console
GRASS GIS trac at osgeo.org
Sun Oct 5 20:45:15 PDT 2014
  Reporter:  wenzeslaus   |       Owner:  grass-dev@…
      Type:  enhancement  |      Status:  closed
  Priority:  normal       |   Milestone:  7.0.0
 Component:  wxGUI        |     Version:  6.4.3
Resolution:  fixed        |    Keywords:  cd, command console
  Platform:  All          |         Cpu:  Unspecified
Changes (by wenzeslaus):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:9 wenzeslaus]:
 > Let's do one more enhancement before closing this ticket. `~` does not
 work. It would be probably better if it would be supported by some
 replace.
 `~` implemented in r62190. Works the same for all platforms although on MS
 Windows this is not expected.
 r62190 adding a feature, so no backport to 7.0 is necessary, closing the
 ticket.
 > I also ask for comments about behavior of `cd` without parameters.
 Currently, it is aligned with behavior of GRASS modules not the original
 bash command.
 I agrre with myself on my original idea, so it is aligned with GRASS
 modules.
 > Also is there something which should be done to improve experience of MS
 Windows command line users?
 The is probably nothing which could be done. What should be done is
 support of their transition to Linux and this, in this case, is already
 done by support of `cd` command and `~` syntax.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2152#comment:10>
