[GRASS-dev] [GRASS GIS] #1936: wxGUI command console: "Protocol" isn't really the right word & cleanup
GRASS GIS trac at osgeo.org
Sun Oct 5 22:02:57 PDT 2014
  Reporter:  hamish       |       Owner:  grass-dev@…
      Type:  defect       |      Status:  closed
  Priority:  normal       |   Milestone:  6.4.3
 Component:  wxGUI        |     Version:  unspecified
Resolution:  fixed        |    Keywords:  command console
  Platform:  Unspecified  |         Cpu:  Unspecified
Changes (by wenzeslaus):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Replying to [comment:8 hamish]:
 > label string rename now applied in all branches. variable renaming not
 yet done.
 Variable rename is not so important and might be done as a part of some
 larger refactoring.
 Closing as fixed.
 > Also I changed it from overwrite existing file of the same name to
 append to file.
 This is surely very useful change, although maybe not expected by all, but
 it's the safer behavior anyway.
 Change done in r56094.
Ticket URL: <http://trac.osgeo.org/grass/ticket/1936#comment:9>
