[GRASS-dev] [GRASS-user] Gauss filter in r.neighbors
Markus Neteler neteler at osgeo.org
Mon Oct 6 01:50:11 PDT 2014
On Mon, Oct 6, 2014 at 9:34 AM, Markus Metz
<markus.metz.giswork at gmail.com> wrote:
> Glynn Clements wrote:
>> Can someone determine whether there's a problem with
>> "r.neighbors gauss=..." in 6.x?
> There is no problem with the Gaussian filter, but a problem with the
> output map type of r.neighbours in G64: the output type is in G64 the
> same like the input type, whereas in G7 the output type depends on the
> chosen function. That means, if you use r.neighbours method=average in
> G64 with a CELL map, the output is also CELL.
FYI - the related (bulk) backports from trunk to relbranch7 were these:
r59668, r59678, r60456
(in case of further backporting to GRASS 6)
markusN
