[GRASS-dev] [GRASS GIS] #2442: np.float128 does not always exist
GRASS GIS trac at osgeo.org
Tue Oct 7 02:56:48 PDT 2014
 Reporter:  jradinger  |       Owner:  grass-dev@…
     Type:  defect     |      Status:  new
 Priority:  normal     |   Milestone:
Component:  Default    |     Version:  svn-trunk
 Keywords:             |    Platform:  Unspecified
      Cpu:  x86-32     |
 When compiling the latest SVN (62197) of GRASS7 trunk I run into following
 error (first among the error list, mostly in the temporal dir):
   File "/usr/local/src/grass7_trunk/dist.i686-pc-linux-
 gnu/scripts/t.vect.univar", line 66, in <module>
     import grass.temporal as tgis
 gnu/etc/python/grass/temporal/__init__.py", line 29, in <module>
     from temporal_vector_algebra import *
 gnu/etc/python/grass/temporal/temporal_vector_algebra.py", line 420, in
 <module>
     import grass.pygrass.modules as pygrass
 gnu/etc/python/grass/pygrass/__init__.py", line 15, in <module>
     from . import raster
 gnu/etc/python/grass/pygrass/raster/__init__.py", line 35, in <module>
     from grass.pygrass.raster.buffer import Buffer
 gnu/etc/python/grass/pygrass/raster/buffer.py", line 14, in <module>
     DCELL = (np.float64, np.float128)
 AttributeError: 'module' object has no attribute 'float128'
 make[1]: *** [t.vect.univar.tmp.html] Error 1
 Here I am running Python 2.7.3 with numpy 1.9.0.
 Here [http://stackoverflow.com/questions/9062562/what-is-the-internal-
 precision-of-numpy-float128] it says that is is related to the
 architecture. In my case I am on a 32 bit system.
 Changing from np.float128() to np.longdouble() (which exists on my system)
 should solve the problem.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2442>
