[GRASS-dev] python2/3 and GRASS build on Arch
Wed Oct 8 04:04:01 PDT 2014
Maciej Sieczka wrote:
>      --with-wxwidgets=/usr/bin/wx-config-2.8
> Per 2.8 wxWidgets specified, I don't get it why
> /usr/lib/python2.7/site-packages/wx-3.0-gtk2/ gets involved in iclass
> build. I would rather expect it to pick
> /usr/lib/python2.7/site-packages/wx-2.8-gtk2-unicode/. Some details:
--with-wxwidgets only affects compiled (C/C++) code which links
against the wxWidges libraries. In 7.0, this means the wximgview
module (visualization/wximgview) and nothing else. It doesn't affect
wxGUI.
In theory, code which uses the wxPython library is supposed to use
something like:
	import wxversion
	wxversion.select('2.8')
	import wx
to ensure that the correct version is used when there are multiple
versions present on the system.
> This is an Arch box. I do have all the NumPy stuff installed. There is a
> problem on Arch that wx-3.0-gtk2/wx/lib/plot.py fails to import
> numpy.oldnumeric [1] leading to those "NumPy not found" errors, but that
> would not happen if iclass build referred to
> wx-2.8-gtk2-unicode/wx/lib/plot.py instead - like I guess all the other
> GRASS 7 Python modules do.
Maybe everything is using wx-3.0, but only iclass is using the broken
plots.py functionality?
If you can run some other g.gui.* module, you can check which
libraries it's actually using with "cat /proc/<pid>/maps", where <pid>
is the PID of the g.gui.* process.
