[GRASS-dev] No Required GUI section for g.list and g.remove
Paulo van Breugel p.vanbreugel at gmail.com
Tue Oct 14 00:14:25 PDT 2014
Putting the 'ignore' option in  separate tab with patterns is fine I
think. Also, for g.remove to have the 'type' and 'name' together in one
tab is also a good idea imho.
I am not sure I understand the last question; you mean to add the
possibility to make an option required but still have the option to put
it in another section? I think that would be a good idea, not only in
this case, but more in general, it would make it easier to create an
consistent interface for modules that require more than a few inputs.
It might be a good idea to flag options as required, e.g., by adding
'(required)' after the option name?
On a side note, why the -f flag of g.remove  is in the 'optional' tab? I
understand it is optional, but as you noted, it is a primary option.. it
is essential to do what the function is suppose to do, remove layers. As
a new user I would not expect such an essential option in the optional
tab I think.
Paulo
On 14-10-14 04:17, Vaclav Petras wrote:
> Hi,
> Anna and I discussed the GUI sections of g.list and g.remove. The
> changes are now in trunk (r62248). However, few issues still remain.
> It seems to us that although `names` and `ignore` in g.remove are
> similar from the point of view of implementation, they have completely
> different use case. While `names` is here to provide a simple
> interface, `ignore` extends the interface which is using patterns. So,
> non-advanced user using GUI will surely want `names` but not `ignore`
> and GUI should reflect this. Thus `ignore` should probably go to
> Pattern (although it is not 100% consistent) and `names` to some basic
> category.
> Also, Required section (of both g.remove and g.list) contains just one
> item - `type`. In case of g.remove, it could make sense to have the
> `names` together with `type` in some Basic section which would be the
> primary section users can focus on (besides approval by -f in
> Optional). This of course expects that no elements will be added to
> the `type` list (#2440, #2437).
> So, the big question is if we want to allow Required section to be
> overridden by another section if it is provided. Currently if option
> is required, GUI puts it into Required section no matter if another
> GUI section was specified.
> Thanks for your opinions,
> Vaclav
> r62248 http://trac.osgeo.org/grass/changeset/62248
> #2440 http://trac.osgeo.org/grass/ticket/2440
> #2437 http://trac.osgeo.org/grass/ticket/2437
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-dev
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141014/14fe9c5b/attachment.html>
