[GRASS-dev] [GRASS GIS] #2452: v.surf.rst option devi Windows problem
GRASS GIS trac at osgeo.org
Fri Oct 17 00:24:46 PDT 2014
 Reporter:  annakrat     |       Owner:  grass-dev@…
     Type:  defect       |      Status:  new
 Priority:  normal       |   Milestone:  7.0.0
Component:  Vector       |     Version:  svn-releasebranch70
 Keywords:  v.surf.rst   |    Platform:  MSWindows 8
      Cpu:  Unspecified  |
Comment(by hellik):
 Replying to [comment:1 annakrat]:
 > Replying to [ticket:2452 annakrat]:
 > > d.vect had at one point problem to display the vector after the first
 run but I was not able to reproduce it, now it displays fine.
 > d.vect gives this, but not always, sometimes it doesn't complain.
 > WARNING: Size of 'coor' file differs from value saved in topology file
 > WARNING: Please rebuild topology for vector map <elev_rstdef_cv at user1>
 > ERROR: Unable to open topology file for vector map
 this seems to be a corrupted vector file after the attempt to overwrite
 it(?).
Ticket URL: <http://trac.osgeo.org/grass/ticket/2452#comment:3>
