[GRASS-dev] [GRASS GIS] #2455: r.unpack/v.unpack: add sanity check for auto-detecting if pack file contains raster or vector data
GRASS GIS trac at osgeo.org
Mon Oct 20 08:22:50 PDT 2014
 Reporter:  neteler             |       Owner:  grass-dev@…
     Type:  defect              |      Status:  new
 Priority:  normal              |   Milestone:  7.0.0
Component:  Raster              |     Version:  svn-releasebranch70
 Keywords:  r.unpack, v.unpack  |    Platform:  All
      Cpu:  Unspecified         |
 Small issue for GRASS data transfer via "pack" format:
 In case that a user doesn't use a self-explaining file name, it may not be
 obvious if r.unpack or v.unpack has to be used. In case of running the
 wrong command, an "ugly" error message appears rather than telling the
 user to apply the other respective unpack command.
 Solution: simply check for the presence of 'mapname/cell' or
 'mapname/coor' and generate a user message if the wrong content was
 detected.
 Message suggestions:
 #r.unpack
 grass.fatal(_("This GRASS GIS pack file contains vector data. Use v.unpack
 to unpack <%s>) % map_name))
 #v.unpack
 grass.fatal(_("This GRASS GIS pack file contains raster data. Use r.unpack
Ticket URL: <http://trac.osgeo.org/grass/ticket/2455>
