[GRASS-dev] tests failed
Pietro peter.zamb at gmail.com
Fri Oct 24 06:05:22 PDT 2014
On Fri, Oct 24, 2014 at 1:05 PM, Martin Landa <landa.martin at gmail.com> wrote:
> 2014-10-24 12:04 GMT+02:00 Pietro <peter.zamb at gmail.com>:
>> However, I would like to revert your change... :-)
>> Introduce the debug message in the Module class it is a bad idea
>> because in this way also Module class is indirectly using ctypes.
>> Therefore all the work done to distinguish and isolate pygrass'
>> submodules that are using the ctypes is not valid any more.
> well, it's _very_ useful info to know which commands are called on
> background. So if you revert it please provide this info somehow in
> other way.
I agree that is useful and this is why I didn't revert it.
So now it provide as a decorator.
