[GRASS-dev] [GRASS GIS] #2443: r.in.srtm.region add-on updates for 7.1svn
Andy Wickert wickert at colorado.edu
Tue Oct 28 09:03:44 PDT 2014
Dear GRASS-dev,
Just sending a nudge about this issue. Since I have fixed the code but
there has been no response, could someone advise me if opening a ticket is
not the best way to communicate an improvement to GRASS? I certainly know
that everyone is busy.
Thanks,
Andy
Andrew D. Wickert
INSTAAR & Geological Sciences, University of Colorado Boulder
Now at:
Universität Potsdam
Institut für Erd- und Umweltwissenschaften
Haus 29, Rm. 153
Karl-Liebknecht-Str. 24-25
14476 Potsdam-Golm, Deutschland
>  Reporter:  awickert     |       Owner:  grass-dev@…
>      Type:  defect       |      Status:  new
>  Priority:  normal       |   Milestone:  7.1.0
> Component:  Addons       |     Version:  unspecified
>  Keywords:               |    Platform:  Unspecified
>       Cpu:  Unspecified  |
>  The simplification in GRASS 7.1 that changes g.list/g.mlist and g.mremove
>  into g.list and g.remove for everything broke some of the functionality of
>  r.in.srtm.region. I've attached a revised file and a list of diffs. My
>  changes check for GRASS version, and while I haven't tested it with 7.0,
>  should allow it to work on both 7.0 and 7.1.
>  I should note that these changes likely broke other add-ons, but that I am
>  in support of the g.list/g.remove change.
>  Thanks in advance for updating,
>  Andy Wickert
> Ticket URL: <https://trac.osgeo.org/grass/ticket/2443>
> GRASS GIS <http://grass.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20141028/d4d40055/attachment.html>
