[GRASS-dev] [GRASS GIS] #2136: Create standard options for map or file base name (prefix)
GRASS GIS trac at osgeo.org
Sun Sep 7 02:33:26 PDT 2014
 Reporter:  wenzeslaus                   |       Owner:  grass-dev@…
     Type:  defect                       |      Status:  new
 Priority:  normal                       |   Milestone:  7.0.0
Component:  Parser                       |     Version:  svn-releasebranch64
 Keywords:  base name, prefix, basename  |    Platform:  All
      Cpu:  All                          |
Comment(by martinl):
 Replying to [comment:25 glynn]:
 > Replying to [comment:19 zarch]:
 > > Should I create a directory in trunk/lib/basename
 > If the functions are accepted, they should go into lib/gis.
 what's the status of this issue? Time to backported to relbr70? I am going
 to increase the priority to blocker because it's related to options key
 names.
 BTW, both G_OPT_BASENAME_INPUT and G_OPT_BASENAME_OUTPUT has the same key
 - `basename`. Wouldn't be better to use `basename_input` and
 `basename_output`? Let's imagine a module which will use both
 parameters...
Ticket URL: <http://trac.osgeo.org/grass/ticket/2136#comment:26>
