[GRASS-dev] [GRASS GIS] #2136: Create standard options for map or file base name (prefix)
GRASS GIS trac at osgeo.org
Sun Sep 7 07:08:44 PDT 2014
 Reporter:  wenzeslaus                   |       Owner:  grass-dev@…
     Type:  defect                       |      Status:  new
 Priority:  blocker                      |   Milestone:  7.0.0
Component:  Parser                       |     Version:  svn-releasebranch64
 Keywords:  base name, prefix, basename  |    Platform:  All
      Cpu:  All                          |
Comment(by wenzeslaus):
 Replying to [comment:26 martinl]:
 > BTW, both G_OPT_BASENAME_INPUT and G_OPT_BASENAME_OUTPUT has the same
 key - `basename`. Wouldn't be better to use `basename_input` and
 `basename_output`? Let's imagine a module which will use both
 parameters...
 I think that's OK. I think that basename as input will be a rare case. For
 `t.*` you use dataset name (and basename as optional for output maps),
 generally you use list of maps (no basenames usually involved), and
 finally, most of the examples we have now has only the output basename
 (e.g., `r.texture`). The rare cases can always change it. But if you
 insist on `basename_output`, I can see why, it would be more explicit and
 also consistent with `output`.
 We can have a look to comment:5 and `t.*` modules how this would work in
 practice.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2136#comment:28>
