[GRASS-dev] What is the status of g.list, g.remove, g.mlist and g.mremove?
Huidae Cho grass4u at gmail.com
Fri Sep 12 18:54:27 PDT 2014
I don't think there is any ticket for it. Was it a blocker for 7.0.0? I
created a new ticket for this (http://trac.osgeo.org/grass/ticket/2414).
There are two major changes:
1. By default, g.mlist prints machine friendly outputs without -p while
g.mlist -p mimics g.list outputs using a pager.
2. g.mremove consolidated multiple options into the type= option.
If merging these modules was planned for 7.0.0 and there are no objections,
I can replace them.
Regards,
Huidae
On Fri, Sep 12, 2014 at 9:05 PM, Vaclav Petras <wenzeslaus at gmail.com> wrote:
> Hi,
> there was an effort to replace g.list by g.mlist and the same for
> g.remove/g.mremove?
> What is the status now and how would the API change?
> We can also have one as a script with different defaults if this would
> help to keep compatibility (then we would be able to make the changes any
> time later).
> If there is some ticket for it, please update the ticket and make it a
> blocker for 7.0.0.
> Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20140912/39ba2450/attachment.html>
