[GRASS-dev] G7: how to get rid of multiple listing of identical map names?
Markus Neteler neteler at osgeo.org
Sat Sep 13 19:10:43 PDT 2014
On Tue, Sep 9, 2014 at 12:06 AM, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Glynn Clements wrote:
>> But there's a rather more fundamental issue here: if G_find_file() is
>> called for an element which isn't guaranteed to exist for every map,
>> it will "find" the first map which actually contains that element,
>> which isn't necessarily the same map as for the other elements.
> OTOH, given that it fixes a fairly fundamental bug, it should go into
> at least one beta prior to any final release.
So that would be r61840 + r61853 to be backported.
But how to test it in trunk?
Markus
